跳转到主内容
加入维修社区 - 创建账户
发布于2016年3月,是一款同时拥有着iphone 6s般的硬件规格以及4英寸屏幕体积的iPhone。有深空灰色、银色、金色及玫瑰金色四种配色以及16/64GB容量可选。国行型号为A1723和A1724。
Unable to lock and boot loop problem
Hi guys, have some issues with my iPhone SE. First issue I noticed was that I was no longer able to lock the phone with the power/lock button, at first I suspected a faulty button, although it feels fine and I’m able to carry out a reset holding the power and home buttons. After trying this, the phone then gets stuck in a boot loop. Once you connect the phone to a charging outlet or to a PC it starts up normally. I’ve tried restoring through iTunes and still having the same issue.
I fitted a replacement battery about 4 months ago, and have had no issues with it until now. It charges up and holds charge fine, so not sure if it’s a battery issue.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hey mate, few questions
Are you a repair tech?
Do you have a microscope handy to take a better look the board?
Do you have ZXW ?
download 3utools - http://www.3u.com/ & post a screenshot of the battery details for me aswell just to take a look at. As bad batteries will cause a phone to go into DFU aswell. Just because it happened 4 months later doesnt really mean anything. Nobody ever has a problem till they have a problem.
you can also read this article on my site on iphone batteries
https://ifixelectronics.com.au/fake-ipho...
这个答案有帮助吗?
得分 0
2条评论:
Hi, thanks for the quick reply!
I’m not a repair tech, just used to taking things and prefer to fix things myself if possible
完成的
I don’t have anything like ZXW sorry. I will open it up later and have a look, everything else is working absolutely fine and wasn’t sure if the two issues were related.
I’m from the UK unfortunately, so it may not be worth shipping all that way
完成的
添加一条评论
添加你的答案
Dom 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 6
总计 119
