跳转到主内容
The Lenovo IdeaPad 300-17ISK is a 17-inch laptop which was released in October 2016. The Model number is 80QH008MUS.
What is LCD cable routing at LH hinge?
Dropped my laptop several times, broke a bunch of “nuts” , LH hinge separated from chassis, replaced the bottom case (chassis) and when I put it back together - no display. I think I crushed the LCD cable on the hinge as I don’t remember the routing and just laid it on top. Can someone PLEASE tell me the proper routing - over, under, around? Note: my 17” hinge is NOT the same as a 15”. The 15” looks to have a slot for the cable to sit in, not mine. Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi,
Not sure if this is a help to you or not.
Here’s a image taken from p.72 of the service manual for your laptop. It seems to show the LCD cable going under (or behind depending on your point of view) the hinge.
(click on image to enlarge for better viewing)
Hopefully it may be of some help.
这个答案有帮助吗?
得分 2
1条评论:
I think it should go under also, but did not see a path in and out. I'll look more at your picture and look again at my hinge area.
完成的
添加一条评论
添加你的答案
pusher44 gmcjb 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 350
