跳转到主内容
加入维修社区 - 创建账户
Samsung's 5th-generation Android-based Galaxy smartphone was released April 11, 2014. Improvements to the phone include a fingerprint scanner, updated camera, larger display, and water resistance. It is available in four different colors; black, blue, white, and copper.
Why am I getting the error message android.process.media.process stopp
my phone was set up for service at MetroPCS. when they began transferring my gallery and files from other sd card to S5 it began giving message android. process.media.process. stopped. That had not happened prior to their transfer. I returnedvto MetroPCS and I saw gallery stopped message also. I have put a 64gb sd card in my S5. But my 500+ photos they transferred are in the air. I am aware I cannot get the photos, but I am wanting this phone checked for repairs.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
The problem is usually caused by a bad or corrupt image stored on the SD card, maybe in the downloads folder on the SD card itself.
This will take some time to find out which one it is so I recommend checking each image with a desktop or laptop you can either use a microSD card USB adapter to plug into a computer or plug the phone into computer and check every image. Any image that does not load on computer (after you copy and/or open it) you should delete it because those ones are causing the issue.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Judith Adams 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 99
