跳转到主内容
Complete repair manual for the PSP Go, including battery upgrade and display repair instructions.
89 个问题 查看全部
PSP go wont turn on when charger plugged in
The PSP turns on and works fine but whenever I plug in the usb charger, the system turns off. The usb side doesnt even have to be plugged into anything, once I jack it into the PSP it will turn off. I set it to USB mode but thing works. The battery still charges though.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Are you talking about a cable? If the other end is not plugged into a USB port and the thing is shutting off, that would suggest the cable you are using may be bad - as in shorted. I would try another cable.
这个答案有帮助吗?
得分 1
1条评论:
Okay thank you I bought three cables on amazon and apparently one of them worked. I assume yes it was causing the PSP to short.
完成的
添加一条评论
添加你的答案
Alejandro Tellez 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 9
总计 320
