跳转到主内容
加入维修社区 - 创建账户
索尼电脑娱乐发布的电视游戏主机。于2013年1月20日发布,2013年11月15日上市。
PS4 doesn't respond to eject button and won't accept discs?
A few months back my son decided to put some quarters into the Blu-Ray drive of my PS4 and I took it apart and removed them and cleaned a little and it began working fine again. But he did it again a few weeks ago and when I put it back together after removing them this time the drive did not respond at all. The eject button no longer beeps when pressed regardless of whether or not there’s a disc in. It will not accept discs automatically, but it can be pushed in and the manual screw works to pull and push discs out. Once the disc is in the system doesn’t even try to read it as if it still doesn’t know there’s one there. I’ve opened it and checked for any obstructions or damaged cables multiple times but can’t see anything wrong. I play nearly everything on digital but I can’t update to the latest PS4 firmware (6.00) and according to the help desk it is because my drive is not working. My system is out of warranty so I’d really like to fix this. I have tried initializing my system both with and without the update and nothing gets the drive responding again.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
If the optical drive was broken the button would still beep when pressed but the optical drive would not eject. This is odd, as there is no beep when pressing the eject button. I would suggest trying the optical drive in the not working PS4 on a working PS4 but that is ridiculous and I doubt anyone you know would let you crack theirs open and void their warranty just to test an optical drive. Let’s hope someone with more experience then me chimes in here...
完成的
my ps4 eject button beeps when pushed but will not eject the disk, but it will take it though. What should I do? I'm thinking about getting it replaced.
完成的
添加一条评论
3个答案
最有帮助的答案
Does the PS4 have an eject button where you can click it or do you need to tap on it to eject it?
If it's a tap one check the metal fixture coming from the eject button from the plastic cover of the PS4.
Sometimes this gets bent the wrong way making it not provide contact to the ejection board on the PS4.
The ejection board has a square gold part on the green PCB board that contacts to that metal fixture.
I'm not sure exactly what it's supposed to look like but when I have time I'll update this post.
这个答案有帮助吗?
得分 2
1条评论:
I have a ps4 slim I press the eject button is says there is no disc i tried to insert a disc and the disc slot is sealed not sure what to do any solutions
完成的
添加一条评论
Your disc eject motor is bad, unplug ribbon to laser and try to update,not the one going under the power supply,the wide white one going to laser. If that doesn't work,try laser ribbon and the smallest ribbon,to eject drive motor. Hope that helps this worked for me.
这个答案有帮助吗?
得分 0
1条评论:
Disc eject motor definitely isn't the issue here
完成的
添加一条评论
Hi!
Seems like your blu ray drive isnt getting any power. This problem should be because of a blown fuse or damaged ribbon cable.
Hope that helps.
这个答案有帮助吗?
得分 0
3条评论:
hey i have the same issue but it is getting power it trys to force a disk out during boot
完成的
ive even took the ps4 apart and checked the rollers they are fine it used to randomly say unreconized disk id hit eject on the home menu id hear noise but when i took the ps4 apart there wasent actually a disk inside and now that i put it back together all it does it try to force whatever disk i shove halve way in before booting and it sees that and trys to force that out
and my eject button does nothing aswell
完成的
ive even checked all the cables but im starting to think the cable is indeed my issue the ear part of the cable seems to be ripped off it dosent look like its locking in properly
might try fliping it around and putting the lose side in the easy part to get to and maybe tape it in place and see if it starts working again im just tryna figure out what is faulting tho my daughter bored the drive itself or the cable
完成的
添加一条评论
添加你的答案
Cole 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 38
总计 20,799
