跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
Calls on receiving end very distorted.
I done a charging port, like many before. But this time, the customer then said, when calls are made on the phone, it's very distorted on the other end, do you can't hear the person.
So tried another port, same thing . Unchecked noise cancelling, but still the same thing.
Used voice memo app. And that works perfect?
Any ideas? Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
That’s odd because phone calls and Voice Memos both use the same microphone (according to Apple).
There are 3 microphones in the iPhone.
https://support.apple.com/en-us/HT203792
  • The bottom microphone is for Voice Memo and phone calls. The other microphones serve as error cancellation
  • The (top) front microphone is used for FaceTime calls, Siri and selfie videos with the front camera (FCAM). The top back microphone serves as error cancellation
  • The (top) back microphone is used for videos with the rear camera (RCAM). The top front microphone serves as error cancellation
Make sure you update your device to the latest version of iOS and then try to isolate which microphone is not working properly by trying each individual microphone with the related apps above. Check the microphone port holes for dust and debris which could be attenuating the sound.
If the issue affects more than one microphone, then it could be the Audio Codec IC on the logic board. Anything at the logic board level will require micro-soldering so you would need to find a repair shop that offers those services.
这个答案有帮助吗?
得分 2
添加一条评论
Is it possible that some adhesive or other debris got stuck in the hole for the microphone at the bottom?
Voice memo uses the microphone at the top of the screen by the earpiece.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Duane 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 26
总计 1,183
