跳转到主内容
加入维修社区 - 创建账户
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 128 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
Backlight keeps going out
The phone started by coming on after letting it sit for a while (it would have a small amount of light at the top of the display). After it finally came up, the phone would function for a while with the backlight flashing every now and then. Now I can get the screen to come on other than the faint light at the top of the screen.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
This is usually caused by either a loose connection from phone to screen, blown backlight circuit or liquid damage near the screen connector, or just simply a faulty screen needing replacement.
First thing I would try is reseating the screen cables, next inspect the screen connector on the board for physical damage or signs of wear and tear as this can cause a bad connection to the screen ribbon cables.
Worst case scenario, phone has liquid damage near screen connectors / backlight circuit blown meaning you would need to take the phone to a reputable repair shop that does board-repairs on iPhones.
Follow up to step 21 of this guide on how to unplug the screen cables:
iPhone 6s 屏幕更换
iPhone 6s Screen
Replace a screen compatible with iPhone 6s. Includes all of the small parts preinstalled in the assembly. Features a 4.7 inch, 750 x 1334 pixel IPS LCD Display, Front Camera Assembly, Earpiece Speaker, LCD Shield Plate, Cable Foam Pads, and Sensor Bracket.图片
产品
iPhone 6s Screen
$54.99
这个答案有帮助吗?
得分 2
添加一条评论
Have you damaged the screen or attempted any repairs recently?
Sounds like a damaged Logic board, but coule just be the digitizer
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Gary Stevens 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 228
