跳转到主内容
Released March 2016, 7.0" Galaxy Tablet by Samsung.
Media sound not working? SOLVED
Media sounds not working. Notifications & system sounds are fine.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 13
9条评论
Thanks for the input guys. It's loud & proud again.
完成的
It's working again. Needed some down time I suppose. It's loud and proud once again! Thanks
完成的
Sounds goes up and down by itself
完成的
I have a problem of my new tablet A. It has no sound, i can’t hear any voice . All is set in settings but still no voice
完成的
I waited on my comment to be answered..
完成的
显示更多的4条评论
添加一条评论
3个答案
最有帮助的答案
Also another thing to check is to make sure you do not have do not disturb turned on or turned on as scheduled. Depending on how it is setup it may mute all media sounds.
这个答案有帮助吗?
得分 4
2条评论:
Thanks. It started working after I left it off for an hour.
完成的
Thanks... checked and it was my “Do Not Disturb” mode was on. Don’t know how it got enabled but it was in and fixed my problem.
完成的
添加一条评论
If your tablet is anything like mine when you hit the volume keys there is a dropdown, maybe the media tab is all the way down.
Alternatively you could have somthing wrong in the system. I had a problem like this where i had to go to a boot menu and clear some temporary data on the
这个答案有帮助吗?
得分 1
1条评论:
Thanks. It started back up after I left it off for an hour.
完成的
添加一条评论
Make sure it is not connecting to a Bluetooth device
这个答案有帮助吗?
得分 0
1条评论:
Thank you thank you thank you Malcolm, that was the solution for me. My tablet was connected with my hearing devices, which lay around somewhere in the living room.
完成的
添加一条评论
添加你的答案
Richard 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 24
过去 30 天: 104
总计 23,339
