跳转到主内容
It was a six-wheeled tank with a front-mounted blue photon beam headlamp, and a keypad on top.
No Power for the photon light, the keyboard or the motor.
This big trak is the late 1970s model.  Many years this big trak was stored in an attic where the summer heat was very high and the winter was cold.  When cleaning the attic I found my old toy and hoping to get it running again.  It was not stored with batteries.  Could the motor and electrical system be ruined from the years of the heat and cold in an attic.  New batteries, four D and one nine volt and not a sound of movement.  Do you have any suggestions, can it be fixed?  I would like to see it run again or should I take it to the recycling center?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
已选择的解决方案
Wow! What a coincidence, as I just found one of these in my parents basement. Manufactured the same year too. My parent’s basement is heated and cooled so the one that I found works okay. For your situation you probably are gonna have to throw it out, sad to say. The electrical in these toys are susceptible to damage in high heat situations as well in extreme cold situations too. Sorry to say it but it is probably dead… ;-(
这个答案有帮助吗?
得分 1
2条评论:
Thank you for your reply. I felt a little disappointed but feel you are right, that the extreme temp differences have ruined the big trak. I seen there are used big traks on amazon for twenty-five to forty-five dollars. Even if I could find a new motor and keyboard, it would cost more than one on amazon. I might as well put the big trak in the recycle center. Again, thanks for your in put.
完成的
@kah116 No problem! Rest in Peace Big Trak :,(
完成的
添加一条评论
添加你的答案
kevin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 389
