Why is my iPhone 6 plus stuck in boot loop?
my iphone 6 plus is stuck in boot loop and it wont restore or update on itunes. it so has a dent on the volume buttons which stop the buttons from working could that be the problem?
Many things can cause a boot-looping device. Give us more history (especially the how and when of the dent!) by commenting on this answer.
Try these things (if you haven't already) to see if anything helps:
Otherwise, you may have a logic board issue. If you are uncomfortable doing these steps, consider finding a repair shop to do the troubleshooting. A shop that also does micro-soldering can go deeper if the problem is not modular in nature.
这个答案有帮助吗?
it fell out my pocket while i was going up the stairs and the dent is preventing the volume buttons from functioning i tried all the methods you listed and still nothing so i want to know if the buttons can cause the phone to be in boot loop
The volume buttons are on a different flex than the power button but I wonder if the dent is causing other issues elsewhere. Can you post a picture of the dent?
i put my logic board in an other iphone and it boots up well but the touch only works sometimes and when i hard reset it the phone goes into a bootloop so i have to disconnect the battery and reconnect it for it to boot up. what do you think is the problem?
Boot-loopers are the hardest to troubleshoot. At this point, it's clear you have a logic board issue and there isn't much you can do, really, from a DIY standpoint. At some point, it will have to be looked at by a micro-solderer.
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 9
总计 190
