跳转到主内容
Why a certain website is freezing on loading the page?
I check if the problem is present on a different computer , and from the same router machine. And there is no problem. So the router is not blocked. It must be an IP related blockage. Thank you. Also... I suspected maybe is a special dedicated virus for blocking a website on a specific IP? I scanned my computer with an AV (antivirus) Malwarebytes and nothing is found.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
6条评论:
is it only one website? or do a bunch of websites not work? if it's only one what is the specific website?
完成的
hi, its a NSFW type of website and there are a couple of them having the same symptom (loading partially or not at all).
完成的
Are you using any ad blockers on your browser or anti-virus on computer? They may interfere with the websites and cause issues like that.
完成的
I found the problem - It was from DNS.
Now, I have further problem. In DNS setting , there are 2 options. If I set the first option : "obtain DNS server address automatically", after some time (not immediately after I close and reopen it) the option switch to 172.98.193.42 in the other option : "use the following dns server addresses". I read that the last number over 30 it means security for childrens ,etc.
I have click on "Advanced" button in the same window with DNS options, I go to DNS tab, and there I could see and delete the adress. When I delete it from there, in the firts DNS options, automatically switched to "obtain DNS server address automatically".
----------->part1
完成的
----------->part2
The problem is that, again, after some time (not immediately after I close and reopen all these settings) the option switch to 172.98.193.42 in the other option : "use the following dns server addresses". I don't know what is triggering the option to switch back. My impression/guess is that is commuted when I access these types of websites. I didn't made the test yet to be certain of the cause.
Please advice, where could be the main trigger?
Thank you!
完成的
显示更多的1条评论
添加一条评论
1个答案
Hello nice to meet you, have you tried clearing your browser’s cache and cookies? Sometimes your browser will store old code and try to re-use it when requesting a website you have been to before. Make sure to clear all of the cache, including: history, cookies, and cached images and files. Make sure you clear the whole history and not just the last 7 days. Hope this helps, talk to you soon
这个答案有帮助吗?
得分 0
2条评论:
It sounds like a background running service or process is monitoring your DNS settings and changing them for you. It could also be a group policy set by the domain server. You have to figure out what is changing your DNS settings by investigating the services you have running.
完成的
oh, thank you. I will do that.
完成的
添加一条评论
添加你的答案
teodoric8 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 18
总计 282
