跳转到主内容
A1706/EMC 3071—于2016年11月上市,这台13''MacBook Pro带有OLED触摸条。以双核“Skylake”英特尔酷睿i5 CPU和4个雷电3端口为特征。
239 个问题 查看全部
Why does my screen go off when I open my Mac, beyond 45 degrees?
My screen goes off immediately when I open my system beyond an angle of 45 degrees.
I can no longer use my system and I was told I have to replace the screen.
Where can I get the entire display unit and can I fix this myself?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
1个答案
已选择的解决方案
Sadly, your display does indeed have a problem. One or more of the ribbon cables has failed these cables are part of the display assembly. So far I’ve not found the part on the open market so you’re only hope is to go to either an Apple Store or Apple authorized service center for them to do it. I strongly recommend you save your paperwork as I’m sure Apple will be offering a extended warranty program for this defect in the parts design.
If you have any bad or sticky keys, you might want to bring your system in for the free extended warranty program for it (Apple Store), see what happens when you don’t extend the display too far showing them the key defect, then when you pick up the system after the repair, extend the display see what they say and do ;-}
这个答案有帮助吗?
得分 0
3条评论:
Many thanks for this Dan. I actually sent it to an apple shop in Accra, Ghana. I was told the entire screen has to be replaced. I had my doubts whether the problem was diagnosed correctly. You may be right.
完成的
@ericlartey - You'll see you're not alone here, I think we now have over 20 reports on IFIXIT now with display cable issues. All of the newer 2016 to 2018 13" & 15" models use the same design and all have been having the same run of issues.
完成的
My MacBook Pro has the same problem just as yours. I left it on my desk for a couple of hours and when I turned to it, the screen just didn't show stuffs. I thought that it was a totally black screen but I wasn't, it was showing things but with extremely low brightness. Then I bought a monitor to keep using the macbook. Today when I opened macbook screen slowly, I found out that it can show things perfectly when the angle is below 60 degree, so it must be the cable issue.
完成的
添加一条评论
添加你的答案
Eric Lartey 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 9
总计 928
