跳转到主内容
三星旗舰手机的大号版本。发布于2018年3月。
130 个问题 查看全部
What is the small movable green line on my screen and how do I get rid
I have this small green line that has shown up on my Galaxy s9+. I can move it around but as far as I can tell, it does nothing. I’ve tried rebooting and all but no avail. I kind of thing it must be tied to an app I installed but I can’t figure out what one. Any ideas?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Hi,
Try starting the phone in safe mode and check if the line is still there.
If it has gone then the problem is being caused by a downloaded app.
As you say the trick is to find out which one.
Try to recall when the line first appeared and then check if you downloaded/installed/updated any apps around the same time.
You’ll need to uninstall each downloaded app and test the phone in normal mode, between each uninstall, to check if the line is still there.
Once it has gone then the last app that you uninstalled is the cause of the problem.
这个答案有帮助吗?
得分 1
1条评论:
Found the problem. It was an app I installed that tracked the amount of time I spent on the phone. Thanks for your help!
完成的
添加一条评论
Hi,
If you have your backup, then format your phone. Hope, so this will help you.
Thanks
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jeremiah Ketchum 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 936
