跳转到主内容
iPad Mini4 Wi-Fi版型号A1538指南 。iPad Mini3的后继版本iPad Mini4 发布于2015年9月9日。
97 个问题 查看全部
Black screen (no backlight?) after LCD replacement.
Hi everybody!
I have replaced LCD in my iPad Mini 4 (A1538). Everything was ok for circa 30 min.
Suddenly, unit made some beepy noise and screen went black.
I was trying few different screens (including original one) but same symptoms: no picture.
iTunes is recognizig it after connecting, so I’m guessing that is backlight related issue (battery was disconnected during replacement).
I have found a lot of information how to fix such malfunction (replacing fuse, filter, making a jumper) but nothing directly related to that model. There is one movie on YouTube: https://www.youtube.com/watch?v=8ElCx1Ep... but mainboard of my unit has no visible damages, nothing is burned and all elements seems intact.
Can somebody guide me what should I do in such case? Post a picture with elements to check/replace?
I wan to buy: https://www.ebay.ie/itm/Ipad-Mini-Backli... as a spare parts.
I’m quite sure that I can do soldering myself, but I can’t find schematics for A1538.
Thank you in advance
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
There is no schematic available for the iPad mini 4. The only way to do board level work on this model is to compare to the other mini’s and the Air’s and infer functionality based on similar design. You’ll need to be patient and jump around from one schematic and board view to another. ZXW at least has the connections mapped out for the mini 4 but no other information.
The linked video shows pretty clearly where the backlight filter is. Probe it and see if it is showing continuity and then probe it in diode mode to see if the circuit is giving a decent reading (~.325). On the LCD connector (smaller one), the Anode pin is the 12th pin from the left on the bottom side of the connector (assuming the short connector is at the top of your field of view and the long one is at the bottom). The three pins to the left and three to the right are the cathode return pins. Start with that and try to determine if there is anything obviously wrong.
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
Backlight iPad Mini 4
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Ijon Tichy 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 5
总计 1,558
