跳转到主内容
发布于2016年3月,是一款同时拥有着iphone 6s般的硬件规格以及4英寸屏幕体积的iPhone。有深空灰色、银色、金色及玫瑰金色四种配色以及16/64GB容量可选。国行型号为A1723和A1724。
1053 个问题 查看全部
I saw the connector of battery on iPhone se and 6 and 6s are the same!
So I have a question that if it is possible to replace 6s plus battery to iphone se?
I saw an article that the connector on iphone se is the same with iphone 6,6s,6s plus, even 7 and 7plus too.
and someone tested if they are compatible to each other, and it worked.
If it’s true, se users can replace battery with 6s plus or 7 battery then it can be used better battery capacity? if iPhone se has 6s or 7’s battery?
Thanks mates!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
5个答案
已选择的解决方案
Well, the iPhone SE has the smallest footprint of all those devices so you won’t be able to physically fit anyone of those batteries inside the SE housing. But yes, you can connect them when the phone is opened up and techs do this for testing all the time.
这个答案有帮助吗?
得分 4
2条评论:
To be clear, as per OP's photo, SE and 6S/6+/6S+ are compatible BUT NOT IPHONE 6 (called 6G in the photo). I learned this the hard way just now when I took out my SE battery to troubleshoot my wife's iPhone 6, and could not connect them...
完成的
If I connect iphone 6s plus on my iphone se. Will battery timing increase ? ?
完成的
添加一条评论
It will connect, but physically it would not fit in the phone. And i am unsure if the phone would power up with it connected.
这个答案有帮助吗?
得分 1
1条评论:
Just trim the battery. Use a scissors. I tried it and it worked perfect.
完成的
添加一条评论
Will a battery out of a iPhone 7 fes or a iPhone set a iPhone
这个答案有帮助吗?
得分 0
添加一条评论
I have a spare iPhone SE battery, is it possible to use it on a 6s?
这个答案有帮助吗?
得分 0
2条评论:
Did you figure out?
完成的
Did you get an answer for this
完成的
添加一条评论
I tried this out and it works the iphone SE 1 gen battary works on the iphone 6s and fully functional and the battary health would be the same as if you got it brand new test it out even and it will work for you
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Mango 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 21
过去 30 天: 74
总计 10,704
