跳转到主内容
Repair guides and support for the fourth generation of Ford Mustang, including the Mustang GT and Mustang Cobra.
58 个问题 查看全部
power loss when accelerating
I need help I have a Ford Mustang GT 2004 and the problem I get is when I step on the car does not react aggressively and begins to pull speeches but at 2000 revolutions takes off is a period of time in which the engine dies. I already change coiles, new spark plugs, filter zagolina, service to the injectors and remains the same as any recommendation would be quite grateful
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Check your compression . Any drop in compression will hurt the performance. Is you car losing coolant? Is it casting any codes ? If so what ? Was there any misfires before you changed out the plugs and coils . If so you may be dealing with back-pressure from the catalytic converter. Raw fuel in the converter can cause it to plug and a plugged converter kills power . Also do you have an aftermarket tune on the car . Change out the air filter as well so it can breath Just a few things to look at . Hope this helps
这个答案有帮助吗?
得分 3
2条评论:
it acts like tractioin control it takes off better if I turn it off
完成的
So what’s the problem? What exactly do I need to fix if I changed my spark plugs and nothing changed oil changed. After market pipes caused my Cadillac was clogged
完成的
添加一条评论
添加你的答案
José saracho 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 17
过去 30 天: 53
总计 2,648
