跳转到主内容
Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
correct bracket for SSD upgrade
I attempted to install SSD in my 2007 iMac. I purchased an inexpensive bracket from an online auction site. I found out the side screw holes are too small — the four screws from the iMac mounting bracket won’t fit.
Can someone recommend the correct brand and model that would work for 2007 iMac?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
This is what I use OWC 2.5" to 3.5" Drive Adapter Bracket
这个答案有帮助吗?
得分 1
添加一条评论
Thanks for the suggestion. A physical visit to the store located a bracket with the correct size screw holes. I discovered another necessary item for installing SSD into a 2007 iMac is SATA extension cables (data + power). The existing cable is positioned for the original 3.5” HD with zero slack; needed to extend the cable by about 2 inches to reach the new 2.5” disk.
这个答案有帮助吗?
得分 0
1条评论:
You'll need to reverse the frame to get the length.
Don't forget putting the thermal sensor back on.
完成的
添加一条评论
添加你的答案
AJJ 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 223
