跳转到主内容
加入维修社区 - 创建账户
2016年9月16日发售。型号有A1661,A1784和A1785,支持GSM 和 CDMA 格式,存储容量有32GB、128GB以及256GB,颜色有玫瑰金、金色、银色、黑色、新的亮黑和红色。
Screen randomly turns on after locking..
So I recently replaced my iPhone 7 Plus screen as it was cracked all over, and the LCD was turning black in many spots. I replaced the screen and everything was working great. I got functionality back in my front camera and such, but I’m having an issue with the phone randomly lighting up to the lock screen like I’ve clicked the power button. If I remember correctly, near the end of the other screen’s life, it was doing this. And also now, the power button is also kindly weird, if I hit it in a certain way or length of time, it cuts off. I thought the screen replacement would fix it, but apparently not. It still works great, but the battery drainage is for real. I was curious if anyone knew what could be causing this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
I’m having this problem about 6 months after having screen changed due to water damage I had it fixed and it’s been fine until now any help ???
完成的
添加一条评论
2个答案
最有帮助的答案
Are you sure it isn’t due to the raise to wake feature being turned on?
You can access that setting with the help of this linked guide from apple:
https://support.apple.com/en-au/HT208081
这个答案有帮助吗?
得分 2
1条评论:
Well that's what I thought at first, but I checked it and it was off.
完成的
添加一条评论
This is going to be water damage. My crystal ball says that your cracked screen had degraded to the point that a few drops of water got into the phone at the top left side of the phone. You likely have some corrosion around the power button and nowhere else in the phone. This corrosion is doing all of the things you are complaining about:
Rapid battery drain—because some line is short from corrosion
Screen turns on by itself—-whenever the corrosion drops the power button line to zero (as if you pressed the button)
Power button is wonky—-due to corrosion at the power flex.
This is a really common spot for a drop of water to land, and it is sometimes the only spot that gets water in a 7plus.
Solution: Take the screen back off after disconnecting the battery, remove the shield covering the power flex connector on the far left end of the motherboard and clean it with a qtip and alcohol.
这个答案有帮助吗?
得分 0
9条评论:
Would the corrosion be noticeable to the naked eye?
完成的
probably not, but maybe. You'd have to pull off the sticker that surrounds the connector. Magnification and a trained eye would help a lot.
完成的
Well, I tried what you asked, meaning I ended up taking the screen off again, did that, plugged it all back in afterwards, and boom. Black screen! I got response from the home button, but nothing on the screen. So I saw a place that had been scuffed up on the connector, figuring maybe I had just gotten a bit too rough, and decided to get a replacement. Well, the replacement comes in today, I hook everything up, it works, perfectly. I didn’t like the way that the home button was seated, so I turned off the phone, unseated everything, reseated, and boom! Black screen! I have no clue what I’m doing wrong, but I am so frustrated. Apparently phone repair isn’t for me..
完成的
I just wanted to get a feel of it, but I keep doing something wrong...
完成的
You have to be religious about disconnecting the battery every time you ever plug or unplug any connector.
完成的
显示更多的4条评论
添加一条评论
添加你的答案
Landon Garrrett 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 2,071
