JURA F50 Switching Off in random times
Hi everyone,
I have the Jura F50 Classic modal.
Problem: The machine is turning off at random times.
(The machine was working for 2 year on the same power outlet.)
What i have checked:
1) Its not the switch-off menu timer.
2) It might turn off in the middle of making a coffee or after few seconds that is turned on.
3) I have replaced the temperature Fuse connected to the thermoblock.
4) I examine the power board & everything looks sparkling new.
5) No discolored wires found anywhere.
6) I unplugged & re-plugged all the connectors (in case of corrosion).
Please let me know if forgot something else to check or maybe replace?
If you help me fix my precious morning kick, coffee is on me! ;)
Thank you all for checking on this issue :D
Kind Regards,
Alex
Any resolution? I have en Ena Micro 9 that’s pulling the same stunt.
由 Justin Lincoln 完成的
