跳转到主内容
Repair guides and support for Lenovo's line of consumer-oriented laptops, the IdeaPad series, first announced January 2008.
1094 个问题 查看全部
IS this connector for an M.2 SSD? Lenovo Ideapad Undocumented JSSD1
Lenovo Ideapad 110 171IKB 80VK - i5 7200U - HD620 GFX
MB: Nano 7C1 - Comes with 1TB Spinner
The attached image is the inside of the laptop (obviously)
I’ve searched everywhere for information about this model supporting
a M.2 SSD. Clearly the connector is present, but it doesn’t seem to be anywhere
in the manual or elsewhere.
  • What kind of SSD would it support? NVME?
  • Many M.2 SSD’s are 80mm long, and evidently this model has a reused motherboard from another laptop, therefore not designed for it. The space as shown in the image is 70mm, so it would require moving the CD/DVD Rom connector daughterboard ‘over’. For me this is fine as I am going to switch out the dvd drive for a 3rd SSD, including changing the original main drive as well. Further, I would have to fabricate a mounting point for the single screw at the bottom of ‘said M.2 SSD, not a problem for me, I have several 3d printers ..or some hot glue :)
If anyone can shed some light on what kind of SSD is compatible that would be Ultra Excellent, as I dont have stores anywhere here, and I’d like to order the right one first.
PS, KEEP UP the good work iFIXit! We all have your back!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Bumperz :P .......
完成的
Excellent, thank you for your reply, yea i think i came across that vid in my travels, but i couldn't ascertain if it was close enough to this machine, looks completely different and the main board is different. i agree regrettably that it's likely just a standard m2 - darn, nvme is like 4 times faster- howevenanor, Faster than a spinner anyway :) I just thought because it's using this newer Nano 7c1 board, it may have inherited some good genetics from a higher model. At any rate Thank you for your time.
完成的
添加一条评论
1个答案
已选择的解决方案
Yep that M.2 slot supports a standard m.2 data SSD, don't think NVMe would work on the low end model of ideapads here is a youtube video showing that it works:
https://youtu.be/QymaSJTUzEs
这个答案有帮助吗?
得分 4
添加一条评论
添加你的答案
Maegan M 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 79
总计 6,808
