跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2690 个问题 查看全部
Phone screen not working
The screen is black but is still lit up when I press any button, I can still press things and I hear it responding like when I touch it to put the passcode. It makes the key noises. But the screen won’t display anything. How can I fix it at home
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
You tried Resetting the device obviously i assume.
Was it dropped? Did it go into water? Was it bent?
Sounds like a bad screen, There should be guides, and i believe the tools you would need to replace the screen on this site here.
这个答案有帮助吗?
得分 0
添加一条评论
can you tell us what you were doing prior to the black screen? Is the phone hot? is your phone damaged in anyway (software - memory at full capacity, outdated firmware, hardware - dropped it, used a really really off brand charger that messed up the motherboard)
If you want to fix it at home, I would first plug it in your computer and check on itunes to see if your computer recognizes your device. If so, back it up and do a factory reset or restore it to a previous time when your phone was working.
if neither of these work, open up your phone and check the screen digitizer circuits and your battery. what do i mean by battery? you could have a faulty battery (therefore it’s swollen and beginning to press up against the motherboard, causing issues)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
daphne morffi 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 33
