跳转到主内容
加入维修社区 - 创建账户
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 128 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
Part of 3d touch not working
So i got an iphone 6s. Lately my 3d touch has become faulty as follows. Just a part on the lower end of the touchscreen doesnt recognise the pressure. The touchscreen works fine, just the pressure isnt recognised and just on a specific area. Sometimes i put a lot of pressure and starts to work but after i charge my phone it goes and i have to repeat the process. Again no problem whatsoever with the touchscreen. Any idea?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
It was the battery all along. It had become swollen and put pressure on the screen from the inside. Got it repaced and now it works like a charm. Thank you all for the help.
完成的
Hello Mikel, I am having this issue as well, but I am not sure whether it's the battery or the screen. What other issues did you have that prompted you to replace the battery?
完成的
添加一条评论
2个答案
已选择的解决方案
If you have tried all of Albert’s suggestions, then you likely have a defective screen. You can replace it yourself but don’t buy an inexpensive replacement as you may have problems with the 3D touch again. You’ll want to get a good quality replacement screen from a reputable vendor.
这个答案有帮助吗?
得分 2
添加一条评论
Before going furiously, make sure you have the 3D Touch turned on.
These are basic troubleshooting that has already helped users to resolve the issue. You may try them out.
1. Adjust 3D Touch sensitivity
In order to change it, go to Settings → General → Accessibility → 3D Touch. Tap and drag the slider to Light or Medium according to your comfort level.
2. Press and hold, don’t drag
Make sure your finger doesn’t slip on the screen, which will result in tap and hold function and not 3D Touch. Press the app hard enough with still fingers and check if 3D touch is working.
3. Reset all settings
Resetting settings will not delete any of your data. It will just reset all the settings to factory state.
Let me know if they work. Thank you!
这个答案有帮助吗?
得分 1
2条评论:
Tried everything before. Even the hard reset through itunes and started as a new phone. Still the same. Only a particlar area of the screen doesnt recognize the pressure its very odd.
完成的
Sorry it didn't help, and thank Minho gave a kind suggestion, but be careful when you assemble your device, hope that will work to you, good luck!
完成的
添加一条评论
添加你的答案
Mikel Kocaqi 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 6,283
