跳转到主内容
加入维修社区 - 创建账户
Nokia Lumia 920由诺基亚开发并于2012年11月发布,搭载Windows Phone 8操作系统。
Phone is acting weird like it was back button pressing itself.
Phone is new. It was never used before. It was unboxed from the sealed package. After powering it is acting strangely. It vibrates and it looks like back button is being pressed constantly.
I have opened it up.
When it is opened it is not doing that but I can’t use opened phone :)
Any help will be appreciated. ( I have tried to change touch sensitivity but it wouldn’t help)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
If the bottom lights are flashing it usually means the battery is flat and needs to charge up to turn on.
Leave it plugged in the charger for about an hour and it should turn off.
If you just opened it up sealed in box don't forget to insert the battery. (I could be wrong but this model may not have user battery)
这个答案有帮助吗?
得分 1
1条评论:
It is not power issue. Phone is charging without problems. Its starts also without problems but after a while it acts like back button was being pressed repeatedly. It vibrates and all apps/setting are closing...
完成的
添加一条评论
添加你的答案
smallbigsquare 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 3
过去 30 天: 9
总计 292
