Charging problem. Usb port is ok
The usb port is working fine .but while charging it shows 9 hours to fully charge. I have clicked the fast charging option .Unfortunately no change is observed. Wireless charging is working fine.whats hould i do
Are you using a wall charger that says Adaptive Fast Charging (9.0V @ 1.67A) and is the wall charger an original one (or even try another wall charger + cable)?
Make sure you are using that wall charger and a good cable like this one:
If it’s still not working and the charging port looks good condition then the issue is either the charging circuit needing board-level diagnosing or there is liquid damage / corrosion behind the charging port that needs to be taken care of.
I have seen some cases where an S6 / S7 phone would suddenly stop fast charging for no apparent reason and then we end up not being able to fix it as we have tried replacing the charging socket via soldering and test with a replacement charging daughter board.
That’s the worst case scenario because that points to the charging circuit on the logic board itself being at fault which means you would either have to replace the logic board being the easier choice or diagnose the charging circuit on the board via board schematics which is very tedious to do.
这个答案有帮助吗?
Use original Samsung adaptive fast charger
Factory reset
Replace Sub pba
Replace S2 diodes and resistors on bottom of MB if you look under microscope you can see S2 written on 2 black diodes, replace those 2 and the resistors on the same track below them
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 674
