跳转到主内容
Released May 2015, identified by model number SM-T350. Features 8.0″ TFT capacitive touchscreen, 5 MP camera, Wi-Fi, GPS, Bluetooth.
118 个问题 查看全部
Samsung Tab A 8.0 (P355) Battery Drain
Hi I got Samsung Tab A 8.0 (P355) sent in to me for repair regarding battery percentage decreasing while charging. After changing a new battery, the battery percentage are increase.
But when the Tab are not charging the battery was draining very fast (1 minute 5% decrease).
What is the possible problem ? Does the cause came from the charging IC ? I dont have the schematic for P355. So What should I do next ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Try to Factory reset your Tab it will default all of your settings, the reasons why the is so fast to drain is because of the usage and performance..
When your Device is in the idle mode try to off (Wifi, Data, Bluetooth and other apps. including the other tab)
这个答案有帮助吗?
得分 1
3条评论:
So u mean do I need to erase everything ?
完成的
Try to do the 2nd option When your Device is in the idle mode try to off (Wifi, Data, Bluetooth and other apps. including the other tab)
When the 2nd option doesn't work you must do the 1st option, Back up your Files First.
完成的
Mine is doing the same thing,i have turned of my wifi,data,app ect.it was good for a few days than it started again,charging slow,and even losing % on a charging mode.did the above help the previous comment.
完成的
添加一条评论
likewise, draining fast and losing percentage while charging. Maximized battery conservation options are not pretty.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Azim WHITE 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 8
总计 2,569
