Why won't my game cut on?
My game was sitting on the top of the dresser and the cat knocked it over now it won't turn on.
The cause of the problem is not an easy fix but sometimes it is. Take a look at some of the most common causes of this problem.
Power Cord. Sometimes the cause of the problem is simply just that the power cord is not plugged into the back of the PS4 fully. Check to be sure that the cord fits tightly into the plug on the back of the console.
Bad Power Button. Sometimes the PS4 power button can cause the not turning on problem. On the original Playstation 4 consoles, they put a touch sensitive button on them. This button had a metal piece inside the case that then touches a copper pad on the motherboard. If this metal piece gets bent or out of place then it can cause a no power problem. This is especially common with opened and/or dropped consoles.
If you can’t fix it yourself, it's going to be better to send it in to repair experts instead of trying it yourself and causing more damage that will cost more to get fixed.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 71
