跳转到主内容
The third generation of the DJI Phantom series released in April 2015.
59 个问题 查看全部
Motherboard (ESC) has an short circuit between + and -
Hello:
My ESC mainboard (Phantom 3 Standard) has an short circuit. I can’t see any damaged component (looking with electronic microscope), but tester indicates 00 (total cotinuity) between + and - of battery power.
Oviously if battery inserted and try to power on, battery detects the short circuit, blinks some seconds and power off.
I unsolded component between VCC and GND, but short circuit continues and component seems good.
I can’t find scheme and I don’t know where to look.
Please, any help?.
Thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
To identify the short, you need to test each component individually. Most motherboards have obvious traces that you can follow to each component. If you can get a part number off of a component, you may be able to look up it’s resistance and voltage requirements.
这个答案有帮助吗?
得分 0
添加一条评论
Thanks Justin.
Here is my ESC:
Between VCC and GND is short circuit.
SMD component up of GND has left pin to GND and right pin to VCC (it seems to be an diode). Oviously tester indicates full continuity (00). I have desolded it and component is not in short circuit, and continues the problem between GND and VCC…
This is the only component that I can see between VCC and GND, but the component is not guilty.
GND track continues to 3 pins (down to up) of SMD component in the left with 4 pins (by side), and VCC continues from right of (diode?) to right of (capacitor?).
Here is my ESC with track painted:
I have desolded full IMU board and full WIFI/RF module, and short circuit continues.
Thanks!!.
这个答案有帮助吗?
得分 0
1条评论:
please remove the diode into the input and check the driver in each motor, The diode is into read line, but you need remove using any desolder
完成的
添加一条评论
try to turn on drone, then check component on board with hand that become too hot, probably arround hottest component that source problem
这个答案有帮助吗?
得分 0
添加一条评论
There are six IC close to each the motor, these are the driver for the motor one of them is in short. I have the same problem, I remove several of these IC. But my motherboard have 6 IC in short.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
fossy_01 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 566
