跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2193 个问题 查看全部
iPhone 4S Only charges when turned off
I’ve recently just got a new iphone 4s,
The day i got it, the charger was 100% working and the next day it seemed to only charge when the phone is turned off and its really annoying to turn my phone off to charge it, is there any fix?
If so, could you reply to this question so i can try and fix it….
I’ve already tried soft reset, hard reset and factory reset and still no luck, i’ve tried restarting the phone and no luck
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
Replacing the charger port usually fixes this problem as it's socket is worn out in most cases.
Here are links to replacement part and guide from iFixit if you want to do it:
iPhone 4S Dock Connector Replacement
iPhone 4S Dock Connector图片
产品
$19.99
这个答案有帮助吗?
得分 2
7条评论:
Thank you, but do you think it might just fix its self?
cause there has been things going around about it just being a bug... and it usually fixes in like 4-5 days?
完成的
Doubt it, like said before usually worn out connector, dust debris in charging socket or corrosion / liquid damage in charging socket.
完成的
I've cleaned out the charging socket and i don't think there has been any liquid in it :/ Bit lost...
完成的
Then the charging dock needs to be replaced, if that doesn't help it's then a board-level issue that isn't worth diagnosing.
完成的
Alrighty, thanks
完成的
显示更多的2条评论
添加一条评论
Try blowing on your charging port and charger
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
William Sims 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 251
