跳转到主内容
The Stealth Pro is a gaming laptop manufactured by MSI. The GS63VR 6RF is a 15.6" model, released in 2016.
10 个问题 查看全部
My screen is making a white and green space
Need a part from my msi gs63 stealth -010
The screen has color damage on the right side making a greens and white box that is annoying to look at when using it . Only appears during dark scenes on the screen such as a black background
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
help us with an image of the error you are facing
完成的
添加一条评论
1个答案
最有帮助的答案
Hi @amal82 ,
Connect an external monitor to the laptop to prove whether the fault is in the laptop's LCD display (or video cable) or whether perhaps the problem is with the GPU or motherboard.
If the external monitor's display is OK then yes you may have a faulty LCD panel (or video cable).
If it also exhibits the same problem then you have a GPU or motherboard problem
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Amal khanna 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 147
