跳转到主内容
14" Chromebook manufactured by HP.
1 个问题 查看全部
My hp notebook computer can not completely boot beyond the logo appear
after doing a dual installation of windows10 and Ubuntu 18.04 operating systems on my notebook, the windows operating system has stopped working. when i select the windows OS at boot up the message'“ windows automatic repairs “ shows up and the process does not go beyond this level. when i try to re install windows 10 on the notebook, the process begins but the machine does not identify any hard drive and so i am hooked up. please i need help.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
have you installed both the operating systems in the same drive without creating partition
完成的
添加一条评论
2个答案
It’s possible that if you haven’t created partitions that some Windows files have been either over written or corrupted. Wipe the drive clean, partition it for each OS then install them again to the relevant partitions.
这个答案有帮助吗?
得分 0
添加一条评论
Here is a web article that gives a pretty complete rundown of how to do that correctly.
https://www.itzgeek.com/how-tos/linux/ub...
It sounds like you have damaged the UEFI boot for your windows. You will probably need to restore/reinstall win10 from either external media or from repair partition if your machine has a repair partition (most do that I’ve seen recently). If you have to reinstall windows and you also have important information on the machine you will need to get the information off of the HDD with a rescue bootable CD of some type (live linux cd most likely). Hope you have another device to research needed steps on the web in that case.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
mbah bangsi 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 7
总计 97
