跳转到主内容
加入维修社区 - 创建账户
2017 年 9 月 22 日发布。型号 A1864、A1897。有 GSM 或 CDMA 版本可选,存储空间为 64 GB 或 256 GB,颜色有金色、银色和深空灰色。
iPhone 8 Plus Backlight/Black Shadow Problem
Hey!
My iPhone 8 Plus has a black shadow on the right bottom corner of the screen after I changed the LCD Screen. Could this be a bad Backlight IC? If yes where is the Backlight IC on the motherboard and would changing it fix the problem like it does on the other iPhones. Couldn’t find anything on the internet for the 8 plus regarding the issue I have.
Thanks,
Fahad
Update (08/27/2018)
I checked the motherboard and turns out the pin 45 was bad on the J5700 connector. So I flipped the board to check the fiter/fuse and the small C5733 is bad. What do I replace it with?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
5个答案
最有帮助的答案
The shadow is because you have one of the two strips of LEDs that make up the backlight not working, and it is usually not working because it has an open line in this scenario. You create an open line on the backlight circuit either through damaging a pin at the connector, or connecting a screen without first disconnecting the battery which can blow the backlight filter, or if you have a water damaged induced short (or spontaneously occuring) on one of the two backlight circuits.
You’ve already ruled out bad screen which was another possibility, so you know this is a logic board repair. You can either buy all the equipment and learn how to do microsoldering and board level troubleshooting (iPhone 8p backlight is not bad for a beginner project), find a local microsolderer or use a mail-in logic board repair service.
这个答案有帮助吗?
得分 2
2条评论:
Yep the lower right backlight strip is probably not working. Where is the BL IC/Filter on the Motherboard since I can’t find it online.
由完成的
Look it up on the schematic. If you need help, then tell us what you are thinking as you look at the schematic and we will let you know if you're on the right track. Start at the connector and try to figure it out.
Step one is to figure out if you have a short or open on the backlight anode and cathode lines for either backlight circuit on the 8 plus.
由完成的
添加一条评论
theres a chip on the lcd flex in the lower right area, it maybe isnt aligned properly and causing it to push on the lcd
这个答案有帮助吗?
得分 1
3条评论:
Nope, Installed the old LCD back and same issue. Lower right has a black shadow.
由完成的
did you try the screen without clipping it in to see if the shadow is still there
由完成的
Yes it was there when out too.
由完成的
添加一条评论
Is the backlight coil is a long ic located next to the charging port conector. Put pressure on it and see if the black shadow goes away.
这个答案有帮助吗?
得分 1
添加一条评论
just replace it the U5600 ic problem slove
这个答案有帮助吗?
得分 1
添加一条评论
not working this
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Fahad Zareef Khan 将永远感激不已
浏览统计数据:
过去 24 小时: 17
过去 7 天: 23
过去 30 天: 38
总计 11,366
