main board (CPU) is overheating even when turned off.
The main board (or it looks like the CPU) is overheating at more than 100°F once the battery is connected even when turned the phone is turned off. (I’ve torn the device down and have removed the peripherals i.e. charging board, camera, antenna etc to rule out issue with them)
Is something shorting it?
It does work though I mean it turns on and functions just fine.
I have tested a different battery just to rule it out. and it's still getting hot whenever the battery is connected. IT does work though like even if I leave it running for 30 mins, it just turns hot, its like having left it inside a car under the sun for 30mins
由 tri5kmark 完成的
