跳转到主内容
加入维修社区 - 创建账户
7.9 inch display / Model A1432 / Available in black or white / Announced October 23rd, 2012 / 16, 32, or 64 GB capacity
FPC connector socket replacement
Is the FPC connector socket interchangeable with a different model?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Which FPC connector are you referring to?
I’ll assume you are referring to the digitizer FPC as that is the one that fails the most. Apple does a great job in using different connectors almost all of the time ;>). They use different types and genders on virtually every generation of device, with only a few exceptions. The mini digitizer FPC is used on the mini, mini 2 and mini 3 but no other FPC used through out their product lineup is the same. You can find it here.
Replace the digitizer cable connector on the logic board of an iPad mini. This part requires microsoldering.图片
产品
iPad mini Digitizer FPC Connector J1700
$2.99
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
dreaminbeech 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 78
