跳转到主内容
Released September 2013, identified with model number T100T. 2-in-1 portable with Quad core Intel® Atom™ processor and 2GB of RAM.
80 个问题 查看全部
Possible to change the HDMI outlet?
Hi guys,
The micro HDMI on my Transformer book seems to be broken. Its no the lan and its not the screen, I ve tried it by using an other cable and an other screen.
I bought an USB adapter instead to connect it with the screen (HDMI to HDMI). Unfortunately its not fast enough for streaming. So my question is:
Is there a possibilty to change the micro HDMI port, or do I have to change the whole motherboard? If its the second it doesnt make any sence.
Hope to find some help here
Best regards
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
the port could be changed but you would need certain tools to remove the old port and solder the new 1 on
这个答案有帮助吗?
得分 2
1条评论:
Thank you for your fast reply, Daniel. Is it complicated to change it, about how long does it take?
完成的
添加一条评论
Just take off the back (I find it easier than my cell back) and crimp the socket gently. I did it with my thumbnail. The metal is pretty soft and easy to bend which is probably why it loosened with multiple use
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Chris 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 670
