跳转到主内容
非一体化电脑称之为台式机。
2133 个问题 查看全部
I Have A Problem Nxzt Kranken With Phankteks Evolv Atx Fan Hub
HI ,
I’m plannıng to buy a new desktop but ı saw my case allready have a fan hub at the back , still my nzxt x52/62 cooler have a same hub , where ı plug my fans and my cooler Nzxt ?
I know ı must plug CPU_Fan 1 slot but which plug ? my case own or cooler.
Example of my cooler cable from net:
(I don’t ask usb cable because ı know)
And example of my chasis:
My case manual:
Note : !!Not for this title !! 2 months ago ı open a title abouth ssd and now ım using my ssd perfect, ı wıll open a title 2 days later how to do and thanks some peolpe :D
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I would say CPU Fan connection should be connecting directly to the mainboard
CPU FAN >connect to> Mainboard (CPU FAN) connector
For others
Mainboard SYSFAN / FAN connector >connect to your PWM hub….
the other fan connect to the PWM hub …..
reason: some mainboard has limited 3 / 4 pin connector for many fans.
这个答案有帮助吗?
得分 0
1条评论:
I dont understand , where ı plug my fan hub to motherboard ?
Can ı connect at Sys_fan 3 ??
You can see my mobo on top .
完成的
添加一条评论
添加你的答案
Carun 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 48
