跳转到主内容
An E-reader released by Amazon.com on April 27th 2016. The model number is SW56RW.
18 个问题 查看全部
How do I fix the backlight on my Kindle Oasis Model #SW56RW?
The backlight on my Kindle Oasis Model No. SW56RW no longer works. It will not get brighter, and it is too dim to read. I go to settings, and then to the Light, and press the light slider up and down, nothing happens. Can someone offer assistance? Can this be fixed?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
You could try to factory reset the device to see if it’s a software issue. If that doesn’t do anything, then my best guess if that your LCD back light has gone bad and that you may have to replace the entire LCD assembly.
You can purchase a replacement LCD here for around £120: https://www.aliexpress.com/item/Original...
The only other option could be, take it apart, remove the screen and put it back and ensure that the connector on the ribbon cable is clean and seated correctly. The cable may have become positioned wrong from being knocked or dropped.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ally Fitzgibbons 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 15
总计 878
