跳转到主内容
2016年9月16日发售。型号有A1661,A1784和A1785,支持GSM 和 CDMA 格式,存储容量有32GB、128GB以及256GB,颜色有玫瑰金、金色、银色、黑色、新的亮黑和红色。
Changing logic board from different carriers
I recently tried to replace the back of my phone with a 3rd party shell. I lost a piece to the lock button and it doesn’t work anymore. When i finished, my home button stopped working even though i didn’t mess with it. Also there is no sound and no Taptic feedback anywhere on the phone. For this reason i want to buy a phone of the same model and switch out the logic board. My only question is, i use tmobile, the phone i found is sprint. Will my board accept the new antenna or will there be problems with it?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
It has nothing to do with “antennas”, it’s all at the logic board level and the different IC’s used to connect to different frequency ranges. I’m not an expert on what frequencies the various US carriers use ( I believe Verizon is the outlier) but if you want to replace the logic board, finding one that uses the same carrier is the preferable approach.
However, before doing that, why don’t you trackback and check your work, you may have made a few small errors or caused damage along the way. It’s cheaper to replace a broken flex or taptic engine than buy a logic board.
这个答案有帮助吗?
得分 2
1条评论:
Yeah, it’s all complicated.
I actually did end up backtracking a bit. I realized since the front camera, phone speaker and home button were all acting up, and that i never even removed those, that it must be a connection. I opened it back up and sure enough, i had put the top display ribbon upside down. As soon as i fixed it and rebooted, it all worked. Just need to find a power button bracket replacement still
完成的
添加一条评论
Hi!
Yes it does!
though its a different antena it fits!. But only one small problem. if you use a antena that is lock with sprint it wouldnt work.
Hope This Helps!
这个答案有帮助吗?
得分 1
1条评论:
Yeah, id assume the harware fits. Its the software that im concerned about. I know different cell carriers operate at different frequencies, just wondering if that information is stored in the antena or the logic board
完成的
添加一条评论
添加你的答案
Eddie Orantes 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 6
总计 642
