跳转到主内容
苹果2016年对于专业用户的笔记本更新。具有15英寸,2880*1800的Retina显示器, 四核心 Intel Core i7处理器, 256 / 512 GB /1 TB / 2TB 存储空间, 16 GB 内存, 和一个带有Touch Bar的键盘。2016年11月发布,型号为 A1707。
260 个问题 查看全部
vertical bars on my display
My Macbook Pro shows vertical lines on the right side of the display, sometimes it changes to pitch black, sometimes clear lines while sometimes just clear lines.
Images:
https://res.cloudinary.com/ichtrojan/ima...
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
3条评论
Hey! Did you get it fixed? I am facing the same thing, and I went to Apple Care and they said it might be covered under warranty if there is no breakage or outside damage. Did you get it fixed?
完成的
I have the same problem with the exception that my laptop completely went into shutdown mode and will not come back up to function. Apple is doing nothing and accepts no responsibility. My laptop was fresh out of the box and used very little when this issue appeared. Was not bumped, moved or closed with anything in it. So, it's very true that this is a defect with the laptop and/or the workmanship that was involved.
完成的
i had the same thing and it cost me $678 to repair the screen. smh
完成的
添加一条评论
9个答案
已选择的解决方案
Had to replace the whole screen, before I finally fixed it, it started showing the stage light effect and would completely go blank when I fully open the lid.
The only fix way to fix this is by replacing the display assembly
这个答案有帮助吗?
得分 2
添加一条评论
最有帮助的答案
Fist try to connect your Mac with external monitor or tv and check if the bars appear on the Mac display. if yes there is an hardware issue, if no software causing an error to reset press control + options + P + R restart the computer and press these buttons before getting grey screen.
这个答案有帮助吗?
得分 4
9条评论:
I do think this is a slam dunk, the display got a good bang damaging it. No need to test with an external display.
@amily - If it was software the bars would stay within the given apps window, here its across the desktop and the menu bar. This is a messed up display and will need a new one.
完成的
would try @amily
完成的
@danj I really wanna be sure before buying a new display, I have a feeling a cable is not seated properly,, there's literally no sign of crack
完成的
@ichtrojan - I realize you likely don't see any physical damage as the damage is internal within the lid or hinge area.
完成的
Thanks @danj, @amily the rest didn't work but thanks for the help
完成的
显示更多的4条评论
添加一条评论
The signaling is a raw display signal unlike what we've seen in the past. Before we had LVDS, then iDP (also known as eDP) which is what the older retina displays used. Here the signal is not converted as the T-CON board is mounted at the hinge area just above the main logic board.
Here’s an image of the display connections for all of the newer 13” & 15” TB & Fn models.
The signal cabled or soldered to the T-CON and not replaceable or removable without damage.
Sadly, nothing here to fix.
这个答案有帮助吗?
得分 1
3条评论:
So, in other words, I just have to change the entire display unit
完成的
Sadly, yes. I'm sorry Apple did us in making these system harder to service.
完成的
Thanks a lot @danj, would hoard cash for it
完成的
添加一条评论
I had the same issue with a a1989 unit I recently acquired.
as you can see there’s horizontal lines across the display.
after removing the display assembly from the main body. I then removed the adhesive tape covering the contacts for the flex cable to t-con board on both sides. Then used flux and went over the contacts with fresh leaded solder. There’s tiny holes in each contact that flows the flux and solder thru onto the board side went over both cables a few passes with the solder iron to make sure it’s adhered and connected well. Replaced the adhesive tape covering the contacts with original one or uses kapton tape if original wasnt reusable. Then reassemble.
Has been working fine for the last 48hrs. Not 100% how long the fix will last. Hopefully mixing in some leaded solder into the unleaded solder Apple used makes the repair last longer.
这个答案有帮助吗?
得分 1
1条评论:
bravo ! I haven't ran into this yet, but offerup has a laptop with this problem and it screams "banding" which is similar to your fix, but easier.. either way if one side of the connection from the tcon board isn't good, your going to get this type of distortion and its usually fixable with a sorta kludge fix or like th eone described above.
完成的
添加一条评论
I started having almost the same issue 3 days ago and it seems like it is getting worst day by day…
Is there any other way to check whether it is the Display by itself is the problem or if it’s another issue?
这个答案有帮助吗?
得分 0
4条评论:
完成的
Did you ever figure this out? I have the EXACT same lines on the left side of my MacBook Pro
完成的
The issue is a hardware one either within the LCD panel or the T-CON logic and the ribbon cables to the LCD.
I've now fixed at least 10 of these now. A bang on the black clutch cove damages the ribbon cable connection to the T-CON (when you alter the angle of the display or press on the Touch Bar area it comes and goes) or if you press on the display its self it comes and goes the LCD was damaged. Other wise it's the T-CON logic. Sadly, in all three cases the same repair is needed replacing the display assembly!
完成的
How much do you charge because I’m having the same issue with school going on in looking to get it fixed asap please contact me back with a email at
Uniqueturner00@icloud.com
完成的
添加一条评论
Oy, having the same problem with a 2015 13” MacBook Retina. To fix the issue after consulting this site, I got a used replacement display assembly. $275 later… The problem persists. It is less bad, but different horizontal and vertical lines appear on the screen. Despite restarts, PRAM resets, attempts to re-seat the cable, the works. And they don’t show up on a 2nd monitor.
Don’t know if this was the case with the 1st display assembly (which grew worse and worse, eventually developing solid black blotches of nothingness randomly across the screen), but the replacement display appears to have a “soft spot” on the screen, at the nexus of the horizontal and vertical lines — a place where, if you touch it or put pressure on the screen, the colors of the lines change, but don’t go away. And if you press hard enough, black blotches appear. They are temporary, and disappear after a while. For now…
Like I said, “oy.”
这个答案有帮助吗?
得分 0
2条评论:
Jonathan, on your 2015 Model this is most likely related to the RAM Chips. Sorin from Electronics repair school has a Video on Youtube, showing the problem and how to solve it (reflow RAM). Simply google Electronics repair school + Macbook"
Cheers!
完成的
Thanks so much Michael! I really appreciate the pointer to Sorin’s video.
完成的
添加一条评论
Hello guys, I have MacBook PRO 2016 late Touch Bar 15 inch, few days back after working through when I turned it off. Next morning as I opened the lid I found one green vertical bar, which shows whole screen flickering when I place my cursor on it ( green vertical bar) as I took a screenshot of it to check whether it was a software issue or hardware since the bar doesn’t appear on the screenshot. it’s so annoying. I bought this device in 2017 feb. no idea what to do, please HELP
Update (11/19/2020)
Update (11/19/2020)
Update (11/19/2020)
On white background it would go enormous
no idea what’s happening. Never dropped or any bang ever.
这个答案有帮助吗?
得分 0
3条评论:
You will be blamed for the issue by Apple. They are accepting no responsibility for this problem and it's actually something that went down due to a defect in the manufacturing of the computer. Apple has known about this for years (per the customers who called their attention to this issue) and they continue to sell these defective products. The say you will need to purchase a brand new laptop screen for $795 or $495. A scam.
完成的
Yeah, did you encounter the same problem?
完成的
i just had the same problem, got it repaired at apple store for $678. smh
完成的
添加一条评论
Same problem! Never dropped it , using it in my desk
这个答案有帮助吗?
得分 0
添加一条评论
I had this exact same issue and what it ended up being was my LCD was cracked. I believe it was because I was working outside in the sun and the screen got really hot to the point that when I applied just a small amount of pressure to wipe the screen it cracked the LCD. I ended up ordering a replacement from China on Ebay and fixing it myself.
这个答案有帮助吗?
得分 0
2条评论:
how much does it cost?
完成的
@Adhitama Harya Saputra - The cheapest is a recycled part like this one MacBook Pro 15" Complete Display - Silver, Apple P/N 661-08031 $467 USD
完成的
添加一条评论
添加你的答案
Michael Okoh 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 15
过去 30 天: 62
总计 57,174
