跳转到主内容
2018年7月发布,15英寸 MacBook Pro,型号 A1990,拥有True Tone技术的LED背光15.4英寸显示器,最高6核心的酷睿 i7 处理器。
Why won't my MBP boot from the ext SSD
Had 2013 MBP that died.  Took out the SSD (with iFixit tools) and put it in an Other World Computing USB enclosure (Envoy).  Connects to new MBP 2018 via Other World Computing micro-b usb 3.0 cable with an Apple usb to usb-c adapter.  4 partitions (one aspf and three GUID Mac OS extended journaled) display on the screen and I retrieved the data that was not backed up so that all is well.  Running 10.13.5 and 6.
Then thought I would (for the fun of it) try to boot from the now external SSD.  Nope.  Fails.  See the circle with the line (ie no valid system). Have tried both command-R and system preferences.  Both offer it as boot option.  Have re-installed High Sierra.
Also Disk Utility says the drive is not solid state and is not bootable.
Other World Computing says I need a USB-C to USB Micro-B 3.0 and omit the Apple adapter so have ordered one but...
Why won't it boot?  And why does Disk Utility say it is not solid state and not bootable?
Is true, I retrieved my data so should give up, move on, but am now soaked in curiosity.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
The new 2018 models hav a T2 chip in them unlike older MacBook Pro’s. The T2 chip offers a higher degree of security! As such somethings are a bit harder unless you tell it not to do something. Here is a good Apple T/N which reviews the different security levels About Secure Boot your system has.
Click on the External Boot ‘Allow Booting from External Media’ should resolve your issue.
这个答案有帮助吗?
得分 1
7条评论:
thank you but
is already set to allow ext boot and I have other ext drives that boot
also set to no security
will keep piddling with this
完成的
Was the drive protected in some way?
You may need to send the drive out to someone who can recovery it as it might have been damaged.
完成的
Thanks. The SSD drive shows on the desktop so I recovered all files. But now that I have it, I thought would try to boot from it. And cannot figure out how to make it boot reliably.
完成的
Try this hold the Option key when you reboot the system that will allow you to gain access to the startup Disk manager, then select your external that should do it.
完成的
Thanks but more than half the time it does not show up with Option boot, even if I connect the drive at the time the drive selection appears.
完成的
显示更多的2条评论
添加一条评论
添加你的答案
Loren Engrav 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 1,096
