跳转到主内容
HP Officejet Pro 8620 is a multifunction printer for copy, scan and duplex. This device can be identified by its model number: SNPRC-1401-02
16 个问题 查看全部
Removal of the right side of the case of an Officejet Pro 8625?
I cannot for the life of me figure out where to unlock the right (*edited) side panel near where it attaches to the paper feeder. I see the tabs on the underside and the entire thing is separated except in that area where the light grey part I’m trying to pry apart presses against the black plastic for the paper feeder.
I’ve been able to remove the left panel and back panel with no issues, just stuck on this side here. Anyone have any tips?
Thank you ahead of time for any help!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
I know I’m late to the party but, just for anyone who needs to know in future, if you look inside the printer from the front on the paper exit tray you will see two little tabs that you can push down. This will allow the paper exit tray to be removed revealing a small screw that holds the panel in place.
这个答案有帮助吗?
得分 1
添加一条评论
It doesn’t come off as illustrated in step 4 here…
HP Officejet Pro 8620 Motherboard Replacement
The text says “pulling down” there but down in the photo would actually be toward the back (normally verticle) side of the printer.
这个答案有帮助吗?
得分 0
1条评论:
This is what happens when you spend too many hours messing with a printer--I actually meant RIGHT side. It's currently upside down and my brain is no longer cooperating. Thank you for the answer. That side is a breeze, it's the other that I'm having a disastrous time with.
完成的
添加一条评论
添加你的答案
Tammy 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 16
总计 726
