跳转到主内容
第三代 Surface Pro 平板,发布于2014年6月20日。
Screen won't turn on after replacement, computer is running.
I have just plugged a screen replacement for the microsoft surface, and though the fan is running and the computer is definitely on, the screen won’t so much as even light up. My old screen was doing this before removal, but it had been cracked for some time.
Is it possible something is blown on my motherboard? I may have forgotten to remove the battery connector before removing the initial cracked screen.
I’ve also considered that it may just be a fried ribbon cable.
Any help would be most appreciated.
Update (08/20/2018)
The bridging pieces are still there for sure. I had read something about the driver possibly being messed up when the computer gets turned on without the screen attached. I definitely turned my computer on after removing the screen initially to see if it was still operational.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
So that's all anyone has for me? Seriously? Just the one answer that gets regurgitated regardless of the problem?
完成的
添加一条评论
2个答案
已选择的解决方案
Have you tried using a micro HDMI cable to an external display to test that it is actually running? That should work even without the LCD attached.
这个答案有帮助吗?
得分 1
3条评论:
yup. thing was my minidisplay was also broken, but just today i received a dock and am using the computer in question to type this comment
完成的
Then I can only imagine three possible answers. Either you put the connector bridge in the wrong way (it will go in upside down), the cable got damaged, or the LCD you received is defective.
完成的
It was the LCD cable! thanks so much
完成的
添加一条评论
最有帮助的答案
The battery and display connector have a bridging piece with pins on it which can be very easy to lose when you remove the screw and cable from the connector on the board.
Those are required for a connection to the ribbon cables.
这个答案有帮助吗?
得分 1
1条评论:
Not my issue. both bridging connectors are in place. I have already researched this issue enough to have covered such bases.
完成的
添加一条评论
添加你的答案
Norman Wolfe 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 2,210
