跳转到主内容
加入维修社区 - 创建账户
This laptop includes a 15.6 inch screen display, 500GB hard drive, and an Intel Core i3 processor. Released in February 2012, it is identified by model number NP300E5A-A02UB.
Headphones/ laptop Jack socket problem
Hello i’m new here i got a problem with my laptop jack socket for headphones. When i plug my headphones in only left one is playing, but when i lightly push the plug down then both works just perfectly, my guess is that somethings wrong with jack socket, maybe some contact is slightly bent or something, any idea if i can bend it back i i have to search for new jack socket? i tried looking inside but its hard to see which one is the one odd.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
You’re sure it’s the laptop socket that’s faulty, and not the headphone plug, I presume. With a magnifying glass and the light shining into the socket as best as you can get it, you may be able to see something. There’s a small chance that you can bend a contact using a pin, but you are quite likely to make it worse. The left channel is the tip of the jack plug and the right (giving trouble) is the next ring on the plug. The troublesome contact will therefore be around a quarter of an inch from the bottom of the socket, i.e. half way down.
Most laptops are fairly straightforward to take apart and this seems to be no exception (https://www.youtube.com/watch?v=WrMbmV2d...). From the video, I can’t see where the headphone socket is but replacing it shouldn’t require more than average soldering skills. You just need to make sure the replacement has the pins and fixing tags in the same places. You might be able to get a spare for your specific laptop on eBay.
这个答案有帮助吗?
得分 0
1条评论:
Yea i checked headphones on different computer and on phone and they work great, and left one works with laptop only after pushing it slighly down. On ebay i hadn't found any seller with this model of jack who imports to Poland.
完成的
添加一条评论
DEVICE NAME-dell inspiron 153000
in my laptop headphone jack is not working
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jacek Kaszycki 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 21
总计 274
