跳转到主内容
2018年7月发布,15英寸 MacBook Pro,型号 A1989,拥有True Tone技术的LED背光15.4英寸显示器,最高6核心的酷睿 i7 处理器。
205 个问题 查看全部
2018 15" MacBook Pro issues with external display
I just purchased a 2018 15" MacBook Pro and when I plug in my external monitor, the text has this shadow which makes it hard to view for long periods of time. I have a 2017 MacBook Pro and it has no issues.
 I tried 3 different monitors and mDP and DP and still the same results. Anyone else have this issue? See the screenshot below.
Update (08/20/2018)
here you go. I used Excel. Same issue but easier to see.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Review your display settings I think you've got them mis-set (both system & display)
完成的
添加一条评论
1个答案
The screen shot won't show the effect as it goes directly to file vs what you see on the screen. You'll need to take a camera to take the picture of the screen.
Do make sure you have no glare on the display by your background and have enough light the camera takes a good image. If you can do a side by side with the same file that might help.
Are you using an Apple cable (displayPort or Thunderbolt)? Or are you using someone else’s? Also who’s adapter are you using?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
mwu1876 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 281
