ps3 slim turns on then right back off
The ps3 slim was giving to me by my sons friend. His father through it though the window and the cover cracked and now it will not start. I know but I - We should be able to fix it with the right parts or knowledge.
When I plug it in there are no lights but when I press the power button the red power standby light comes on. I press it again and the green light comes on, out lights on power and disk buttons come on, and the fan runs for a sec then it shuts down with all lights out.
I tried holding the power button in to check the video output and try to reset but it shuts down after a sec. It only beeps once when I first press the power button.
4条评论
any luck funny enough ive got the same issue picked up a slim that had been thrown now when you starts up turns on then off and nothiing else was just wondering if you have found a fix yet
由 eric 完成的
I ordered the security driver so I can open it to see. I will let you know if I find anything. Please do the same if you find the problem.
由 Paul 完成的
Did you try throwing it back in through the window to undo the problem?
It could at least surprise your "son's - friend's - father" ... smirk!
由 The Chad 完成的
I’ve had the same problem with my PS3 Slim 2501b. I replaced the hard drive and ultimately ps3 kept doing the same thing turning on when I push the button and then off. So flustered, I took the whole ps3 apart down to the motherboard, cleaning everything and inspecting every little detail. Without finding anything out of the ordinary I put everything back together...However! I did not put the top case on yet before I screwed the top shell back on Because if it didn’t work I didn’t want to take it apart again. So leaving the top off I turned the ps3 on and it worked! Oddly enough, when I put the top she’ll back on and screwed everything in, and hit the power button again it started doing the same thing again. Why? I just put the top she’ll on and screwed it back on. Anyways I kept messing around with it until finally I found out that the ps3 does this because of a bad ground, metal touching metal. By leaving it in screwed slightly it works. It has to be bad ground
由 Brandon M 完成的
