跳转到主内容
2.4GHz, 2.7GHz, or 2.8GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache. Released February 2013.
20 个问题 查看全部
MacBook Pro A1398, 820-3332A Logic Board TSOP Error
Hello,
I have a 2013 Macbook Pro 15. 10 seconds into the bootup the fans go full throttle, the MacBook is slow to boot, and once it does manage to boot the CPU is > 100% at all times.
  • Ran AHT, it reported – 4SNS/1/40000000 TsOP—124
  • Bought a new trackpad with cable, replaced. No change, same issue.
  • Removed the logic board, cleaned everything and reinstalled. No change, same issue.
Any suggestions / help would be deeply appreciated. Thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Check the logic board thoroughly for damage; blown components or damaged sensor circuits can cause this issue. Test it will just the charging port, fans, SSD and trackpad connected; if the fans still go full speed it will be logic board related.
If it is logic board related, I would suggest taking it to a repair centre to check out; a decent repairer will know areas to check and will determine what is causing the fault.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Mandeep Singh 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 221
