跳转到主内容
The Apple Watch Series 1 is a revamp of the original Apple Watch, announced September 7, 2016. Most of the parts are the same as the Series 2
123 个问题 查看全部
Replace Apple Watch battery with more capacity?
First of all,
Can you place a 273 mAh battery (e.g. from Apple Watch Series 2, 38m) into Apple Watch Series 1 (38mm) whose original battery is 205 mAh? will it be compatible?
Secondly,
If that works, will it be safe?
Finally,
What about generalizing the conclusion to other version of Apple Watch (or even to other product of Apple)?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
The different series have different batteries which are not interchangeable as the connector interfaces are very different.
Series 1 - 205 mAh (38mm) 246 mAh (42mm)
Series 2 - 273 mAh (38mm) 334 mAh (42mm)
Series 3 - 279 mAh (38mm) 352 mAh (42mm)
The space the battery sits is larger in the Series 2 & 3 watches so the battery within them is larger unlike the older Series 1 which has a thicker logic board so the space the battery is limited.
这个答案有帮助吗?
得分 1
1条评论:
Thanks @danj ! I was wondering if replace with battery of larger capacity could extend the standby time lol --- looks like just a fantasy now.
完成的
添加一条评论
添加你的答案
Bill 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 16
总计 797
