跳转到主内容
10 MP camera with 20x wide angle optical image stabilized zoom. Released in December 2008.
11 个问题 查看全部
SX10IS Corroded battery damaged the contacts
The battery door was stuck. I manged
to coax it open after a long ordeal with a tiny screwdriver. Battery leak had damaged the terminals on the inside of that door. I cleaned them as well as I could but one of them is very badly corroded. It easily detatched fro the door but won’t fit securely back. Can I replace the door itself?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
I doubt you’d be able to find parts for it. Try epoxy for structural repairs or hot glue for just keeping things in place.
Use rechargeablesifyou can. If there’s an external charging port, seal the batteries up so it doesn’t fall apart and use it as long as you can.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Jim DiNatale 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 10
总计 304
