Flash on my Nikon P7700 camera will not pop up.
The flash on Nikon P7700 is stuck. It will not pop up.
Thanks James. In my case, the flash does pop up after a few tries. I have to release the latch with a jerk. That helps the flash to pop up. Looks like there is a spring under the flash which has lost its tension with time or maybe the latch might be worn out now.
这个答案有帮助吗?
My Kodak has the same problem. I think the little relay that unlatches it is just a little off adjustment, so I give it a little help with my fingernail sometimes. Either yours is out of whack due to wear or misalignment (damage?), or just permanently broken.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 8
总计 361
