跳转到主内容
Schematics and pictures of circuit board. Very often the wire feeder stops working because of dead relay. You can replace the defective one with a more durable 8A relay.
What is the nominal for R1 resistor?
Hi. What is the nominal for R1 resistor?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
I believe that you are needing to know the power rating of a resistor.
Check these websites and a resistor calculator might help.
calculator:
https://www.engineering.com/Library/Arti...
info:
https://www.electronics-tutorials.ws/res...
这个答案有帮助吗?
得分 0
2条评论:
resistor has burn
完成的
it is 11 Ohms 5%
完成的
添加一条评论
添加你的答案
crazycancer 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 375
