跳转到主内容
Released April 2010 / 2.4, 2.53 GHz Core i5 or 2.66 GHz Core i7 Processors
590 个问题 查看全部
Replaced Battery in April, now won't charge.
I replaced with a battery ordered here. Had trouble with it not charging at first. did a PRAM and SMC reset and it was working. Now am having same problem again with the addition issue that it won’t even run off the power adapter. Power adapter is green but computer will not turn on. Sometimes it will start but then just shuts off
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
This is usually caused by liquid damage, you can either take the board out and inspect it carefully under a microscope to look for signs of corrosion (white marks / rust / burn marks) if you have one or take it to a reputable repair shop that does MacBook board repairs.
It will require at least board level repairs done to it if the MacBook doesn't turn on with the battery, battery indicator light, keyboard and trackpad unplugged.
这个答案有帮助吗?
得分 2
4条评论:
which board am I inspecting?
完成的
The logic board. Here is a guide for taking out logic board if needed:
MacBook Pro 15" Unibody 2010晚期逻辑板更换
Usually signs / hints of where the liquid damage is are shown either on the bottom metal lid cover of the MacBook or the large black backlight cover which is behind the logic board for the key board.
完成的
I tested with unplugging keyboard, trackpad and battery and battery indicator. turns on. What is next? having someone inspect the board? Cheers!
Update. I plugged back in everything except the battery and fans and it starts up.
Update 2. Plugged battery back in, reassembled and everything is working so far. Charging battery at 16%. will continue to update
完成的
Update 3. Was charging for a while. eventually shut down and went back to not working. I unplugged the battery and it will startup without the battery
完成的
添加一条评论
添加你的答案
David 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 72
